Results 1 to 4 of 4
Thread: Cast iron repair using metal stitching
    jdurand's Tools
    The video is from a maker of plugs used in metal stitching
  2. The Following 6 Users Say Thank You to jdurand For This Useful Post:
    Altair (Jan 23, 2023), baja (Jun 5, 2019), olmike (Jun 6, 2019), Scotsman Hosie (Jun 5, 2019), Seedtick (Jun 4, 2019), Toolmaker51 (Jun 8, 2019)
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    I've seen this before. Amazing–if somewhat tedious–process. They've certainly developed the tools, techniques, and inserts, for their proven proprietary system.
    Heard of stitching but isn't close to what I envisioned. I pictured something more like lacing across a crack with a MIG. Since I have a broken casting, sitting idle almost 15 years now. . .
    Thank you jdurand forwarding this post!
    Dry Gulch, Tx
    Crusty's Tools
    I've done this before on a cracked engine block using hand tools. It took a long time to do but it worked in the end.
    ETA: On the other hand, I knew a guy that twisted off a water pump bolt on a six cylinder Ford and when he went to drill it out he kept drilling until he drilled into his #1 cylinder. He was lucky because the piston was down in the cylinder when he drilled. He took the head off, got all the metal chips out, dressed up the hole edges and packed it with JB Weld and when hardened he put it all back together. That car was still running fine two years later when he sold it. I'm jus' sayin' ...
