Results 1 to 8 of 8
Thread: Can anybody tell me what this is for?
    Jan 2016
    Moby Duck's Tools
    Or what I could make using it?
    http://trademe.tmcdn.co.nz/photoserv.../455547683.jpg
    http://trademe.tmcdn.co.nz/photoserv.../455539073.jpg
    ITEM HAS BEEN POSITIVELY IDENTIFIED BY MICK BELOW. Many thanks to all who helped.
    Last edited by Moby Duck; Mar 1, 2016 at 10:12 PM. Reason: Item identified. No longer need help.
  2. #2
    RFS
    RFS is offline
    RFS's Avatar
    New Mexico
    RFS's Tools
    Looks like the base of a chop saw, attach a 7" or 9" grinder and make it a mini chop saw?
  3. The Following User Says Thank You to RFS For This Useful Post:
    Moby Duck (Mar 1, 2016)
    Jan 2016
    Moby Duck's Tools
    That‘s what I originally thought, but that doesn't explain why the support is triangular shaped and the blade slot is so far away from it, or why there are what look like two bolt holes in it. Grinders usually have a bolt hole at the front for the handle but not at the rear. A chop saw is probably what I will try but wondered if it might have some other purpose.
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    I used to have one somewhat similar to that, It is a base to convert an right angle grinder to a chopsaw.
    Work not bad but can be a pain to set up. mine was universal but that one looks like it might be brand specific.
    Good luck Al
    On second look it probably is an universal mount it uses the handle mounts and jamb bolts to position the angle grinder. You will need to find the right bolts to fit your grinder.
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
  6. The Following User Says Thank You to Al8236 For This Useful Post:
    Mar 2016
    Hi,
    This is a Wolfcraft 5019000 Angle Grinder Stand, it lacks some accessories to be able to use it, hope that help.
  8. The Following User Says Thank You to mick_rosoft For This Useful Post:
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Hi Moby Duck,
    It is angle grinder base (for 115~125mm models),
    for convert and use them like a chop saw.
    I have one similar but I have use it, only two times.
    The correct setup it's pain and fiddly each time that you will need it,
    and if you haven't a second angle grinder to burying on it,
    I would not recommend you buying it.
    Regards
    Bill
  10. The Following User Says Thank You to kess For This Useful Post:
  11. #7
    Jan 2016
    Moby Duck's Tools
    Thank you Mick. Exactly the answer and details that I was hoping for. I can now see that there are parts missing and will not be buying it.
  12. #8
    Jan 2016
    Moby Duck's Tools
    Thank you Kess, your advice is appreciated and as it has missing parts I will be taking your advice and will not buy it.
    Thanks to everybody that has helped me identify this.
    My problem is solved.
    Case closed.
