Results 1 to 1 of 1
Thread: Calculating tap drill size
    The suggested tap drills on most charts are the size needed for a 77% depth-of-thread (DOT). If you're working with hard to tap materials, you can significantly reduce the tapping effort and chance of tap breakage by using a smaller DOT with only a very small loss of joint strength. The DRILL program on my website will suggest DOTs and calculate the required tap drill but it's not hard to do it yourself with a desktop calculator.
    The generalized formula for 60 degree threads is:
    TD = MD - 0.013*DOT/P
    where:
    TD = tap drill size
    MD = major diameter of thread
    DOT = desired depth of thread expressed as a percentage
    P = thread pitch expressed as TPI
    As an example, for a 1/4-20 thread with 75% DOT we have
    TD = 0.25 - 0.013*75/20 = 0.201"
    which corresponds to a #7 drill.
    Some of you may be familiar with the simpler formula
    TD = MD - 1/P
    Here the product 0.013*DOT has been taken equal to 1. If we solve for DOT, we have:
    DOT = 1/0.013 = 76.9%
    so the simpler formula will always produce a drill that will yield a 77% DOT which is a bit too much for many situations.
    The suggested DOTs used in my program are...
    MILD AND UNTREATED STEELS 60-65
    HIGH CARBON STEEL 50
    HIGH SPEED STEEL 55
    STAINLESS STEEL 50
    FREE CUTTING STAINLESS STEEL 60
    CAST IRON 70-75
    WROUGHT ALUMINUM 65
    CAST ALUMINUM 75
    WROUGHT COPPER 60
    FREE CUTTING YELLOW BRASS 70
    DRAWN BRASS 65
    MANGANESE BRONZE 55
    MONEL METAL 55-60
    NICKEL SILVER (GERMAN SILVER) 50-60
  2. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Karl_H (Jan 31, 2020), WmRMeyers (May 25, 2023)
