Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Calculating the radius of a circular segment
    Supporting Member Duke_of_URL's Avatar
    Aug 2018
    Texas
    There's a geometric method of solving that problem with a compass, assuming you have a 2-template of the segment:
    Given:
    1) Using a compass create a circle at "A" using as its radius the distance AP:
    2) Now using that same radius, make corresponding circles at points B and P to locate the intersections.
    3) Now using a ruler draw a line through the intersection points of each pair of circles. The intersection of those three lines will be the greater circle's center and the radius follows, as shown.
    Attached Thumbnails Attached Thumbnails Calculating the radius of a circular segment-capture1.png
  2. #12
    Yes, that will work but using the formula will be a lot faster and requires no scaling, no template and no drafting.
    Experience is always far worse than pessimism
  3. #13
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Hi Gang:
    With no math, the two perpendicular bi-sectors of AP and PB cross at the center of the curve. A straight edge and compass job.
    Here is a elliptical shaped concrete slab that is based on a gardener's ellipse done with two stakes and a bit of rope.
    Carl.
    Last edited by carl blum; Jul 3, 2024 at 09:36 AM. Reason: More information added.
  4. #14
    Quote Originally Posted by carl blum View Post
    Hi Gang:
    With no math, the two perpendicular bi-sectors of AP and PB cross at the center of the curve. A straight edge and compass job....
    Yes, that will work but it requires first constructing an accurate drawing that includes the measured values for the chord and sagitta.
