Results 1 to 6 of 6
Thread: Bumper build for a '95 GMC Pickup
    May 2012
    Byron, Michigan
    astroracer's Tools
    I built this bumper for my '95 pickup back in 1999/2000. It's been holding up fairly well for 18 years.
    I started with a raw steel bumper then built the lower air dam out of 10ga. steel, 1 1/2", 3" and 5" dia. tubing.
    Once it was all welded up I sand blasted the whole thing, inside and out and buried it in epoxy primer. I used All Metal to seal up the weld seams on the back side and after priming and blocking I shot the whole thing in white catalyzed enamel.
    Here is the truck last winter cleaned up for the Chrome & Ice Show in Flint.
    Mark
  2. The Following 16 Users Say Thank You to astroracer For This Useful Post:
    baja (Aug 15, 2020), DIYer (Jul 12, 2018), EnginePaul (Jul 13, 2018), Floradawg (Jul 11, 2018), hansgoudzwaard (Nov 13, 2018), high-side (Aug 16, 2020), HobieDave (Mar 21, 2020), jackhoying (Jul 12, 2018), KustomsbyKent (Jul 11, 2018), Little Rabbit (Aug 14, 2020), NortonDommi (Jul 12, 2018), PJs (Jul 15, 2018), Rangi (Aug 15, 2020), Seedtick (Jul 11, 2018), Tooler2 (Aug 29, 2020), Toolmaker51 (Jul 11, 2018)
    Jul 2018
    Flora, MS
    Floradawg's Tools
    Excellent! Very nice indeed.
  4. The Following User Says Thank You to Floradawg For This Useful Post:
    astroracer (Jul 11, 2018)
    Quote Originally Posted by astroracer View Post
    Mark
    Truly, a work of art. Not any injection molding going on there! Bumper, tubing and 10 ga plate components are obvious, along with the serious contouring to seamlessly meld them together. The faired and frenched outer light nacelles are very cleanly developed, radiused openings of the larger lamps too. What was the source of 'stand-offs' [?] supports at either end of the central blade? They look 50's Buick or such. Fabbing of concave edges defies my imagination.
    I hate to guess what a custom shop would charge for it. Yikes!
  6. The Following 2 Users Say Thank You to Toolmaker51 For This Useful Post:
    baja (Aug 15, 2020), PJs (Jul 15, 2018)
    May 2012
    Byron, Michigan
    astroracer's Tools
    Thank you sir. The compliments are very much appreciated!
    The radiused openings for the big lamps were made by hot bending some 1/2" round stock around a mandrel then welding it on the end of the tubing.
    The center supports are simple, crush bent muffler tubing. I welded on and smoothed the side pieces to give them the depth I needed to carry the blade.
    The blade is 10ga. steel with another piece of that 1/2" round stock welded on the front to give it some thickness.
    As far as cost goes I have about 100 hrs. into the fab and finish work. Back when I built it the going shop rate for fab work was 60-80 dollars an hour. So that works out to 6 or 8 grand to have it built... I have less then 200 into it including the paint.
    Mark
  8. The Following 5 Users Say Thank You to astroracer For This Useful Post:
    baja (Aug 15, 2020), EnginePaul (Jul 13, 2018), hansgoudzwaard (Nov 13, 2018), PJs (Jul 15, 2018), Toolmaker51 (Jul 12, 2018)
    Thanks astroracer! We've added your Pickup Bumper to our Autobody category,
    as well as to your builder page: astroracer's Homemade Tools. Your receipt:
  10. #6
    Mark
    Bent tubing, lol but the joke is on me. Straight bends are about the only tricks I have...I don't need a bumper but this makes me want to design more advanced fabrications.
  11. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Jul 15, 2018)
