Thread: building my english wheel
    Mar 2013
    south coast of iceland
    so i want to build me an english wheel most of you build it from square tubing , but i have some beams from pallet racks they can withstand about 1,5 tonn pressur without failing . i was thinking of making my ewheel from that , the beams look like this >--< but the triangles are closed in both enda . it is made of 4mm thick steel the idea is to make two identical c shapes weld them upp so i have 8x3 inch do you think it wil work as a 30 inch throat e wheel .
  2. #2
    Apr 2013
    Brisbane,Queensland, Australia.
    Ron B's Tools
    you need to weld two of the >---< side by side so you could get a box section tube .
    this will make an immensly strong up right,you could then have the right angle to form your throat section in the same manner. What you need to achieve is a frame which wont twist under load. With wheeling machines,the heaviest is always the best.
