Results 1 to 4 of 4
Thread: Building a brake line bending fixture.
    May 2012
    Byron, Michigan
    astroracer's Tools
    I am finally back working on my Astro van project, getting some of the brake plumbing done. I swapped out the stock prop valve for a Wilwood piece and had to reconnect the master to the valve.
    This was a bit of an adventure getting the tight bends that were needed to run the lines.
    I ended up making a little bending fixture to get it done. This will be pretty handy for doing the rest of the van.
    I made the clamp block on the mill. Both ends have their uses and I used both getting the bends into the lines.
    Continued in next post.
  2. The Following 3 Users Say Thank You to astroracer For This Useful Post:
    Paul Jones (Dec 29, 2016), PJs (Dec 30, 2016), rossbotics (Dec 30, 2016)
    May 2012
    Byron, Michigan
    astroracer's Tools
    The line for the rear brakes is in.
    And here is the line for the front brakes.
    This is one of the double flares I do with my CPP Flaring tool.
    Thanks for looking.
    Mark
  4. The Following 2 Users Say Thank You to astroracer For This Useful Post:
    Thanks astroracer! We've added your Brake Line Bending Fixture to our Brake category,
    as well as to your builder page: astroracer's Homemade Tools. Your receipt:
    May 2016
    works great used it to reline my forty nine dodge
