Thread: Building a banjo for the wood lathe
    Supporting Member The Hobby Machinist NZ's Avatar
    Jan 2023
    New Zealand
    The Hobby Machinist NZ's Tools
    In this video I build a quick release banjo for the woodturning lathe. A banjo holds the different types of tool rests that you use when turning. It also allows you to move and position the tool rest in the correct position. Older banjos are held, or clamped in position by tightening a bolt or nut. This can be tedious and time consuming because you need to reposition the banjo often when turning. This banjo has been designed with a quick lock and release system.
  2. The Following 3 Users Say Thank You to The Hobby Machinist NZ For This Useful Post:
    Jon (Apr 28, 2023), lassab999 (Apr 24, 2023), trevor_60_r (Apr 30, 2023)
    Thanks The Hobby Machinist NZ! We've added your Wood Lathe Banjo to our Lathe Accessories category,
    as well as to your builder page: The Hobby Machinist NZ's Homemade Tools. Your receipt:
