Originally Posted by
Frank S
These are simple devices to install usually either roller-less roller chain or leaf chain or can be wire ropes 1 would be mounted to the top of one of the support frame members then pass under a roller mounted on the traveling beam then over a roller on the opposite side then down to the bottom of the frame on that side then the same thing is done in reverse starting at the top of the structure of the opposite side then bringing the chain / cable across and ending up at the bottom
this way if one end of the beam tries to go up the other end must go up at the same amount. Your guides then only have to keep the beam vertical and receive no stresses from any other plane of movement.
