Results 1 to 8 of 8
Thread: Breaking Rock
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Breaking Rock
    Anyone who has had the pleasure of removing set cement from a machine will appreciate this. On smaller mixers some holes drilled and a few gallons of acid help and if lucky big bits can be broken out after a week or two then tumbling large rocks can help. Worst case is some poor monkey has to put in ear plugs, stuff their grade 5 earmuffs with cotton waste, put on the breathing gear and get in with a rock-breaker finishing off with an air chisel in the tight bits.
    I thought this was far better. 100 MPa Carbon fibre reinforced concrete!
  2. The Following 9 Users Say Thank You to NortonDommi For This Useful Post:
    Andyt (May 19, 2021), baja (May 19, 2021), jimfols (May 18, 2021), Moby Duck (May 18, 2021), nova_robotics (May 18, 2021), Scotty1 (May 18, 2021), Toolmaker51 (May 18, 2021), tooly (Jun 5, 2021), Tule (May 23, 2021)
    Dec 2020
    Wow! I followed additional links that appeared of the blasting of rock. I was very impressed! I wish I had learned the trade lof blasting rock, turning it into small enough pieces to remove. I am intrigued!
    One time was enough for me; and it was only a train car!
    Jul 2020
    I've always said that there isn't much that can't be accomplished with the judicious use of explosives. (Grin)
  6. The Following User Says Thank You to the harmonious blacksmith For This Useful Post:
    rdarrylb (May 19, 2021)
    Dec 2017
    NeiljohnUK's Tools
    Major concrete companies in the UK would simply replace the mixer drum on trucks where the mix had set due to traffic delays as it was more cost effective (UK explosives licencing was and is 'problematic') and faster, in the 80's we would pass a field near Little Marlow on the A404 where the old mixer drums were left until a foundations job where they could be incorporated came along.
  8. The Following User Says Thank You to NeiljohnUK For This Useful Post:
    NortonDommi (May 19, 2021)
    Quote Originally Posted by NeiljohnUK View Post
    Get that marked quickly, before subsequent generations think they've found another Stonehenge. I can already see the travel posters!
  10. #7
    Oct 2016
    old kodger's Tools
    They hardly know what the first Stonehenge is let alone worry about a second one.
  11. #8
    Dec 2016
    Ralphxyz's Tools
    Of course someone first had to go and drill the holes for the explosives. Still a miserable job.
    Ralph
