Results 1 to 5 of 5
Thread: Brass Instrument Tubing Benders
    Sep 2015
    I need to know how to make and use with ease a tool capable of bending brass tubing 180°, I believe the dimensions of this tubing are as follow: OD .695" (or ~17.65mm); ID .694" (or ~17.63mm); Pipe wall .0215" (or ~ .55mm). Please advise all information/instructions regarding working with BRASS [tubing]... not copper, steel, aluminum, etc. THANK YOU!
    Krankenmensch
  2. #2
    Hi Krankenmensch - welcome to HomemadeTools.net
    Interesting tool build; please go ahead and post a new thread in the Help Me Build subforum, it has a very good response rate.
  3. #3
    Wie krank sind Sie, mensch?
    Most of the good tubing benders I've seen follow the design described here...
    http://www.modelenginemaker.com/inde...8.html#msg1858
    Plans are included but you will probably have to scale them a bit to the tubing sizes you need.
  4. #4
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi Krankenmensch,
    Welcome!
    What are you planning to build with that brass tubing?
    Ken
  5. #5
    Welcome to the forums, Krankenmensch! Jon and Marv's suggested links look like a good place to start.
