Results 1 to 6 of 6
Thread: Brake Lathe Restoration
    Supporting Member darkoford's Avatar
    Jul 2017
    Croatia
    darkoford's Tools
    Simple tool for turning brake:
  2. The Following 3 Users Say Thank You to darkoford For This Useful Post:
    AmateurMachinist (Mar 24, 2019), Seedtick (Jul 29, 2017), Tule (Dec 28, 2019)
    Thanks darkoford! We've added your Brake Turning Tool to our Brake category,
    as well as to your builder page: darkoford's Homemade Tools. Your receipt:
    darkoford (Jul 27, 2017)
    JeffEck's Avatar
    Jan 2017
    Kansas
    JeffEck's Tools
    Genius! I wish I had thought of that. This morning I spent about 30mins tapping and reading my indicator to get the disc in the chuck perfect... Nice video, nice idea.
  6. The Following User Says Thank You to JeffEck For This Useful Post:
    darkoford (Jul 28, 2017)
    Jul 2017
    Croatia
    darkoford's Tools
    20+ years needed me to simplify the job. Practice while you are alive!
    When I first saw the tittle I thought someone might be restoring a vintage brake lathe like a Van Norman, Ammco, Barrett, Or possibly a Quick-way or Coats which I think were made by Van Norman
    The adapter you made if it had been bored to fit a mandrel would be quite similar to those used on brake lathes since the beginning so good job
    Single cutting disks is often done but can lead to the surfaces not being parallel to each other
    Making or buying a twin cutter assembly is always optimal but hardly worth the expenditure in time materials or money for a one time run Many shope will no longer turn or true disks or drums due to liabilities and labor expense
  10. #6
    great tool.
