I made this Brake Drum Puller with a 16-17” reach from scraps I found in the barn. Needs a few modifications but seemed to work relatively well.
Jon (May 24, 2019), Scotsman Hosie (May 25, 2019)
Thanks YanasaRanch! We've added your Brake Drum Puller to our Brake category,
as well as to your builder page: YanasaRanch's Homemade Tools. Your receipt:
many may scream foul but i've have been where you are several times over the decades, some times a relief cut is nessisary at the drum hub hole a short torch cut 3/4 to an inch cut from hub between lugs toward drums outer dia.
this allows drum to release hub. not ideal but failure or runnin with out brakes can kill or cripple or just smash things.
al
