Results 1 to 6 of 6
Thread: Blasting Cabinet Clean Air Vacuum
    May 2012
    Byron, Michigan
    astroracer's Tools
    I couldn't see spending 600 bucks or so on a canister vac for my blasting cabinet so I built one. I used a couple of kitty litter buckets, a shop vac filter and a Harbor Freight dust collector vac.
    I use one of my shop vac hoses to hook the cabinet up to the top bucket of the collection stack.
    The hose simply plugs into a close fitting hole I cut in the bucket.
    The upper bucket has a shop vac filter bolted into it.
    The air is drawn through the filter out of the bucket through the big flex pipe. Any dust is collected on the filter and doesn't get through to the vac.
    This setup works very well to keep dust down in the cabinet. Well worth the 120 dollars I have into it.
    Plus, it all breaks down and stores inside the cabinet when not in use.
    Mark
    Download plans for media blasting tools.
  2. The Following 10 Users Say Thank You to astroracer For This Useful Post:
    baja (Feb 1, 2020), bukwessul (Dec 27, 2017), clydeman (Jan 31, 2020), high-side (Feb 1, 2020), Janvosburg (Mar 12, 2019), Jon (Jan 18, 2016), kbalch (Jan 18, 2016), PJs (Jan 19, 2016), sossol (Aug 8, 2016), WinDancerKnives (Jul 24, 2016)
    Thanks astroracer! We've added your Sandblaster Dust Collection Canister to our Cleaning category, as well as to your builder page: astroracer's Homemade Tools. Your receipt:
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    One question, how are the bucket tops held together? I mean you must be able to open it to empty, clean filters right?
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
    May 2012
    Byron, Michigan
    astroracer's Tools
    Quote Originally Posted by Al8236 View Post
    The upper bucket was trimmed so it slips inside the lip of the lower bucket. It's a pretty tight fit but, if you look at the last picture, you can just see a sheetmetal screw above the handle that screws the two buckets together through the lip. One more screw on the opposite side.
    I will take them apart and get better pics of the filter and how they go together.
    Mark
    Sep 2016
    how do you have the filter install
    Jul 2012
    Very nice job, K.I.S.S. at it's best. Could be done with round buckets too. Where did you get the vac filter, recovered from a scrap unit?
