Thread: The birthplace of disaster! But covered with good intentions
    May 2017
    Project tries to cut corners and save cost believes that everything can be modified should be modified break more than six and have always relied on my knowledge versus asking for the opinion of others or better Solutions.
    I'm looking for life hacks involving balancing a bench grinder to every other imaginable sitting in the garage.
  2. #2
    Hi AveryGoodkoch - welcome to HomemadeTools.net
    You might like these links:
    Homemade grinding tools
    All homemade tool categories
    Our best homemade tool builds
    Post on the forum with any questions you may have. You’ll get some great responses, and we like discussing tool builds in progress.
    Bench grinders are not what they used to be.
    First investigate condition of bearings or bushings of motor endbells, for both radial and axial play, it can be corrected. There must be a degree of preload in both axis. Also determine inner flanges run parallel, and wheels are flat.
    Test the bare motor, sans wheels, nuts and flanges. Burp or throttle the switch so RPM increases gradually. Insure the mounting or pedestal is bearing evenly on all the feet. A pedestal often responds to bolting down, or a couple felt plies instead of direct contact with uneven concrete floor.
    If the wheels are close to being dressed, the problem usually stems from rather inferior products. If density of bonding and material isn't uniform, no amount of dressing will correct it, until the diameter is 'under' the offending internal lump or void.
    Worry not.
    Make a pair of flanges with somewhat oversize bores, then static balance the mounted wheels. Another technique would be flanges a bit thicker than original, and drill the 'heavy' portions with shallow pockets. If gone a little overboard, those could be filled with lead.
