Thread: A Better Bench Peg!
    SculptyWorks's Avatar
    Sep 2019
    Virginia
    SculptyWorks's Tools
    Lightbulb A Better Bench Peg!
    Is the bench peg a tool or a feature? Either way, I felt I could improve upon the design of mine to better suit my needs!
    So, there's a video of it!
  2. The Following 5 Users Say Thank You to SculptyWorks For This Useful Post:
    glenntref (Mar 28, 2023), Inner (Mar 26, 2023), johncg (Mar 26, 2023), RetiredFAE (Mar 24, 2023), WmRMeyers (Mar 25, 2023)
    Thanks SculptyWorks! We've added your Bench Peg to our Woodworking category,
    as well as to your builder page: SculptyWorks's Homemade Tools. Your receipt:
    WmRMeyers's Avatar
    Dec 2014
    WmRMeyers's Tools
    It doesn't look like your V-notch intersects the vacuum connection. If not, I'd drill a hole near the bottom of the V-notch to connect them. You could use a sheet plastic or metal gate to laid over the large hole in the end to increase draw at the V-notch, or a smaller gate to block it off so the larger hole draws air better, and make it even more versatile.
    For cheap bastriches like me, it could be built as a pine box from scraps so you could avoid using a nice piece of solid cherry wood... Would make cutting the holes a bit easier, too.
    Bill
