Results 1 to 4 of 4
Thread: The Best Tools for cleaning Carbs
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    I have not needed clean a carb in a few years and I am glad that I could not find my old carb cleaning kit
    Using the needle with the precision air flow of the inflator worked like a charm
    Disclaimer ( do not use wires or files to clean small passages in the carb it could effect emissions and performance )
    All of the guys selling the carbs will say not to use anything to clean the small passages
    So what can I do ? buy a new one
    The carb in the video is from a Kolher CH740 on my small bobcat
    It has 20 to 30 hours on the engine but it sat for three years a new carb shipping and taxes and duty about 500 CND
    The last 2 post have been moved am I putting them in the wrong place ?
    Ray
  2. The Following User Says Thank You to shopandmath For This Useful Post:
    Altair (Jul 28, 2019)
    Thanks shopandmath! We've added your Carburetor Cleaning Setup to our Carburetor category,
    as well as to your builder page: shopandmath's Homemade Tools. Your receipt:
  4. The Following User Says Thank You to Altair For This Useful Post:
    shopandmath (Aug 1, 2019)
    Sep 2018
    Have cleaned or rebuilt over a hundred carbs in my lifetime. I have never used anything that is metal for cleaning passages. Only small soft bristle brushes. Along with carb cleaner. Never seen a passage that needed extreme cleaning. Then brake cleaner and a blow out with air.
  6. The Following User Says Thank You to mbshop For This Useful Post:
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Hi mbshop
    thank you for your reply
    you are right in some cases the steel files might be overkill
    on the last job i could not find me carb tool kit so i came up with this one
    this worked very will the air blow tool was awesome nice two hand control what would make it better would be a foot control
    another idea for the very small holes was to modify a real needle braes it to the tip of the inflater
    what do you think ?
    the only help i could get was 1(but a new carb) 2 (soak it in sea-foam)
    Ray
