Thread: Best Portable BBQ Grill || MANGAL
    Supporting Member Andrii Pysarenko's Avatar
    Aug 2021
    Andrii Pysarenko's Tools
    BUY - https://lavky.com/uKM469TFolding brazier-suitcase with 10 skewers - the perfect solution for cooking your favorite dishes in nature. And also a great option for a gift.It has two levels of skewers - top: 9 skewers, bottom: 10 skewers. You can cook at both the upper and lower levels at the same time.Also, the slots for skewers are made on the side walls, in case you have soooooo long skewers.In the lower part of the grill there are holes for air supply, which allows to provide sufficient heat from the coal.The brazier suitcase is made of 2 mm steel.The threadless design allows you to assemble the grill in minutes.There are convenient handles for transportation in both folded and unfolded form.Weight 8 kg. (17)Dimensions:length 510 mm (20)width 290 mm (11.4)height 500 mm (19.7)depth 150 mm (5.9)Case as a GIFT (the color of the case may differ).A reliable helper for picnics and barbecues.
  2. #2
    where is the build part of the vid.
  3. #3
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    There isn't one, he is advertising a product to buy from someone else...
    There is no homemade in this product, bet the sausages were bought as well...
  4. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    Frank S (May 11, 2022)
