Thread: Bender roller combo
    Bender roller combo
    A while back someone posted a unique form of metal bender with rollers for rolling and a die for bending
    I think it was called the ultimate bender or somethin like that
    I liked it well enough to decide to build my own version with a few upgrades
    I put a large bearing where the cams action slide pivots
    just need to insert a bar in the hole to turn the shsaft
    the rollers are cam followers the apex roller has a pipe sleeve pressed over the cam roller with a handle welded to the pipe
    I used 1 bearing cup and 1 end of a u joint cross to be the eccentric drive cam
    the main shaft and ujoint end
    slide plate and main shaft
    cover plate just hand cut
    All plate parts are from 3/8 ASTM 514 (T1) steel 110,000 PSI tensile WHY? because I have it and I can.
    bottom view
    Top view
    It works great for the thicker materials 1/4 to 3/8" but for narrow and thin like 1/8 by half the material is too soft for the spacing of my rollers and the apex roller cannot get enough friction to pull the material through.
    I plan on adding pipes and sprockets on the idler rollers then drive them with a chain later on .
    Also I have not added the holes to attach a bending die at this time since I haven't need that yet.
    I made this a couple months ago and yesterday was the first time I needed it
    If someone finds the thread of the other bender please link it to this thread as I would like to give him credit for the idea
  2. The Following 9 Users Say Thank You to Frank S For This Useful Post:
    Andyt (May 22, 2019), baja (May 22, 2019), Jon (May 20, 2019), KustomsbyKent (Jul 9, 2021), mwmkravchenko (Nov 24, 2022), Scotsman Hosie (May 22, 2019), Sleykin (Jun 1, 2020), that_other_guy (May 23, 2019), Tuomas (May 21, 2019)
    Thanks Frank S! We've added your Bender and Roller to our Metalworking category,
    Tonyg (May 21, 2019)
    Re visiting this thread as per a request of more information from a member.
    he was wondering what the large bearing under the slide was for.
    I made it with the intention of eventually maybe adding angle iron pieces over the rollers to make sharper more defined bends though never got around to doing so I tried using it to make letters for another project out of light gage 1/2" sq tubing but ultimately used another means to form them.
    By inserting a bar in the shaft that extends below the bottom of the machine and rotating it 90° to the left or right the top movable roller functions as that of punch in a press the 2 stationary rollers serve as the die
    DIYer (Nov 29, 2022), Saltfever (Nov 26, 2022)
