Thread: Bench Running a Small Glow Plug Engine
    Apr 2017
    UK
    editor@glue-it.com's Tools
    Thought I would take you through bench running a small glow plug engine. This is quite easy to do, you just need to follow some simple steps and you will be ready to go. Bench running is a good way to get used to starting and tuning these small engines. Even model car engines can be run on the bench with a propeller. This way you can learn in a controlled environment.
    The video takes you through the stages of mounting it, fuel tank, plumbing, propeller and throttle.
    My plan is to build this into something, just not sure what yet....
  2. The Following 2 Users Say Thank You to editor@glue-it.com For This Useful Post:
    Andyt (Oct 27, 2021), Home-PC (Oct 29, 2021)
    Apr 2017
    UK
    I've enjoyed this so much that I made a 2 chamber exhaust silencer
    I probably should have gone back to the equations on exhaust silencer design.....
  4. The Following 2 Users Say Thank You to editor@glue-it.com For This Useful Post:
    Lake Tahoe
    IntheGroove's Tools
    As a child I spent many hours running a Cox .049 on a piece of wood...
