Results 1 to 5 of 5
Thread: Bench Grinder: Angle setting gauge for tool rests
    Oct 2019
    Germany
    uv8452's Tools
    When working on a small machine like the TAIG Micro Lathe it is important to keep the cutting forces small; and to keep the tool bits sharp. That means frequent re-sharpening without wasting tool bit substance. The set angles of the tool rest need to ‚stay’ so that a shallow ‚shave’ is sufficient to remove the growing radius on the cutting edge. A second advantage of being able to adjust repeatably the grinding angle is to work with proven parameters - all the more important with small machines.
    As I didn’t find (and never saw) a gauge or method to adjust the angle of tool rests I built a small gadget which allowed exactly that. Here I’m offering you the basics - perhaps to build your own gadget.
    HMT GRINDER fin.pdf
    HMT GRINDER fin.pdf
    Your comments and improvements are welcome.
    Please tell me if I was too detailed.
    Thank you
    Ulrich
  2. The Following 6 Users Say Thank You to uv8452 For This Useful Post:
    DIYSwede (Jun 15, 2021), elk-a-holic (Jun 15, 2021), Floradawg (Jun 16, 2021), Jon (Jun 15, 2021), Skun Knuckles (Jun 16, 2021), Toolmaker51 (Jun 15, 2021)
    Stockholm, Sweden...
    DIYSwede's Tools
    Smile
    -Thanks for sharing! To me, you could never get "too detailed" as I'm a curious guy!
    Cheers, and welcome aboard HMT - hope you'll find it as interesting and useful as I have!
    Johan
    I like the idea too. Done something like that setting lathe compounds; can't recall applying it elsewhere.
    Supporting Member elk-a-holic's Avatar
    Jan 2016
    When it comes to marh you can never get detailed snd simple enough fo me.
    Thanks uv8452! We've added your Tool Rest Angle Gauge to our Measuring and Marking category,
    as well as to your builder page: uv8452's Homemade Tools. Your receipt:
