Results 1 to 5 of 5
Thread: Belt sander stand
    Jan 2015
    Belt sander stand
    I would like to make a stand for my fur inch Rockwell belt sander which I might use to sharpen tools and small projects made of wood. Any thoughts out there?
  2. #2
    Well I did a search for just stands, and there are more than 700 entries.
    Here are a few belt sander-specific ones - Homemade Tools Search: belt sander stand
    Supporting Member jere's Avatar
    Feb 2015
    jere's Tools
    How big is the foot print of the sander? You might think about using a 2 drawer metal filing cabinet, an older one. They are cheap, easy to put a dolly under to wheel around and they have good storage underneath for extra belts of different grit or a small shop vac.
  4. #4
    Jan 2015
    I use old drums from big trucks to make stands for my stuff. Very heavy and stable, and cheap or free to get. Go to a big truck shop and some will just give them to you, or go to a scrapyard and buy one. Typically 30 cents a lb where I live for steel/cast iron, so a drum costs me less than $30 if I can't get a free one. Drums are nice because without using casters you can move them around easily. I'll post a pic of one I'm building right now when I get out to my shop tomorrow.
  5. #5
    Oct 2014
    Coronado, CA
    Before I learned about using a brake drum from a truck, I used a wheel and tire from Craigs List free section.
    The price was right, some scrap 2" pipe is the vertical member and the rest is welded up from a recycled bed frame.
