Results 1 to 5 of 5
Thread: Beer Keg Furnace - Part Three - Machining home cast aluminium
    Supporting Member Retro Steam Tech's Avatar
    UK
    Retro Steam Tech's Tools
  2. #2
    Sep 2015
    Nice finish, do I see a little porosity in the centre of the chequer plate casting? I've had that a few times!!
    Graham.
    UK
    Thanks Graham. I think I just didn't face off quite enough material. As you can see there was quite a shrinkage dip in the end of the rod.
  4. #4
    Sep 2015
    Hi yes you didn't face off much, sorry about that I wasn't criticising you!! quite a few yrs ago when I first thought to cast myself some bronze bar stock by putting various diam bars vertically in greensand & pouring them,after shakeout & feeling quite pleased with myself [till they went in the lathe to turn some steam fittings for model engines, & they were all porus!!! live & learn eh!!
    Graham.
  5. #5
    UK
    No apology necessary, didn't think you were criticising, just pointing something out. I've done some more machining on the ally I cast and as far as I can see it's fine. Perfectly ok for model steam engine or Stirling engine work, which is what I will be using it for.
  6. The Following User Says Thank You to Retro Steam Tech For This Useful Post:
    the artfull-codger (Sep 17, 2020)
