Thread: Band saw tire brush, aftermarket
    Sep 2013
    western NC
    akaalan225's Tools
    I'm fortunate to own a General Manufacturing band saw, purchased in the mid-80's, it's a shame they're no longer made. It came without a lower wheel brush. I recently bought a little Craftsman band saw for more detailed work that has a very effective tire brush; IMHO it's a necessary add-on. After replacing my General's tires with new urethane tires I decided to make a tire brush from scratch, using the same brush head from Sears parts and the same basic attachment. The part number for these brush heads is S21400-150, I think they were about $8.00 each. I bought a couple plus an extra drive belt as the shipping was more than the parts!
    I traced the profile of the brush holder onto a 1-1/4" poplar dowel, predrilled through with a 1/4" hole and hogged out the inside as well as I could to the appropriate depth, lacking a mortising attachment for my drill press. Sloppy, but it worked to securely hold the rectangular shaft in place.
    I eyeballed where I wanted the brush to sit, drilled a 1/4" hole through the lower cast iron frame. Using a 4-1/2" carriage bolt I secured it to the frame with fender and lock washers and a nut. It's the same basic attachment for my Craftsman and it works great. Project took about two hours to do and i think it would probably work for just about any band saw that didn't feature a lower wheel brush as OEM.
    Photos show 1) the Sears brush in place. 2, 3) Brush head with hollowed out dowel. 4) 1/4" hole drilled in lower frame. 5, 6) installed brush.
    Attached Thumbnails Attached Thumbnails Band saw tire brush, aftermarket-1.-sears-brush.jpg   Band saw tire brush, aftermarket-2.-brush-head-hollowed-out-dowel.1.jpg   Band saw tire brush, aftermarket-3.-brush-head-hollowed-out-dowel.2.jpg   Band saw tire brush, aftermarket-4.-hole-drilled.jpg   Band saw tire brush, aftermarket-5.-installed-brush.1-2.jpg
  2. The Following 2 Users Say Thank You to akaalan225 For This Useful Post:
    chevysman21 (Feb 22, 2016), kbalch (Sep 13, 2013)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks akaalan225! I've added your Bandsaw Brush to our Bandsaws category, as well as to your builder page: akaalan225's Homemade Tools. Your receipt:
