Results 1 to 10 of 14
Thread: Arbor for running little chuck in big chuck
    jjr2001's Tools
    I used this arbor to turn down some nuts for my mill a while back but when I made the new 3/4-16 to 5/16-18 arbor I found this in my tool drawer.
    Now If I have something chucked up in my little shop I can easily move it to my "big shop" and keep it chucked up in the small chuck.
    Whole lotta chuckin going on!
    One other tip with this arbor. The threads are long enough that it can be used as a fixed rod stop.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Arbor for running little chuck in big chuck-img_2059.jpg   Arbor for running little chuck in big chuck-img_2060.jpg
  2. The Following 5 Users Say Thank You to jjr2001 For This Useful Post:
    Jon (Oct 2, 2018), old_toolmaker (Oct 1, 2018), PJs (Oct 2, 2018), rossbotics (Oct 4, 2018), Seedtick (Oct 2, 2018)
    Dec 2017
    Cape Coral, FL
    old_toolmaker's Tools
    jjr2001,
    That's a nice adaptation of that little chuck! Is that a Sherline four jaw chuck? I once had a 3" three jaw scroll chuck mounted on a 5C arbor. It was one of the handiest little chucks I ever had.
    Dick
    Links to some of my plans:
    jjr2001's Tools
    Hi Dick, actually that 4 jaw has been in the shop for over 40 years. Used it on a little wood lathe. It looks very similar to the sherline 4 jaw chuck but it did not have the mounting holes through the face or the groove for mounting on a work plate. I added them after I bought the Sherline. Just got lucky with the 3/4-16 thread so I only needed to make one adapter for both chucks to be fastened to the rotary table.
    Cheers, JR
  5. The Following User Says Thank You to jjr2001 For This Useful Post:
    PJs (Oct 2, 2018)
    Dec 2017
    Cape Coral, FL
    jjr2001,
    Most of the chucks available today are quite thick compared to the one you have. Yours has less overhang and I like that.
    Dick
  7. The Following 2 Users Say Thank You to old_toolmaker For This Useful Post:
    jjr2001 (Oct 2, 2018), PJs (Oct 2, 2018)
    jjr2001's Tools
    https://www.ebay.com/itm/Sherline-La...8AAOSwMHtbnqUm
    https://www.ebay.com/sch/i.html?_fro...22+lathe+chuck
    They are still out there on ebay and I think Sherline still sells the compact type.
    Cheers, JR
  9. The Following User Says Thank You to jjr2001 For This Useful Post:
    PJs (Oct 2, 2018)
  10. #6
    Dec 2017
    Cape Coral, FL
    JR,
    Thanks for the link!! I have a Sherline dealer very near me. I would like to see one up close and personal.
    Dick
  11. The Following User Says Thank You to old_toolmaker For This Useful Post:
  12. #7
    jjr2001's Tools
    Very good. I have a Sherline store (The factory) only 350 miles away. Worth the drive every time.
    Cheers, JR
  13. #8
    Dec 2017
    Cape Coral, FL
    jjr2001,
    You are very lucky to have the factory so close by. What model lathe do you have?
    Dick
  14. #9
    jjr2001's Tools
    I have the 4400 lathe which is the long bed. (16").
    The mill is the 2000 which has setups that approach the versatility of the Bridgeport but with
    the limitation of using it with small parts and cutters only. The spindle taper is MT1.
    Great for the small stuff.
    Cheers, JR
  15. The Following User Says Thank You to jjr2001 For This Useful Post:
    old_toolmaker (Oct 3, 2018)
  16. #10
    Dec 2017
    Cape Coral, FL
    jjr2001,
    Thanks for the information! The 4400 looks like a nice machine. I actually need a mill more than another lathe. I have been doing all my milling in my Micro Mark 7 x 16 mini lathe using a Unimat DB200 vertical head. It is not a good solid arrangement but it works well if I go slow.
    Dick
  17. The Following User Says Thank You to old_toolmaker For This Useful Post:
    jjr2001 (Oct 4, 2018)
