Results 1 to 10 of 17
Thread: Anti-Vibration Technology
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
  2. The Following 16 Users Say Thank You to machining 4 all For This Useful Post:
    baja (Feb 7, 2021), Captn Roy (Feb 10, 2021), fizzloid (Feb 5, 2021), freddo4 (Feb 5, 2021), jimfols (Feb 4, 2021), Moby Duck (Feb 5, 2021), NortonDommi (Feb 6, 2021), nova_robotics (Feb 4, 2021), Paul Jones (Feb 5, 2021), Rangi (Feb 4, 2021), Raytonian (Sep 13, 2021), Scotsman Hosie (Feb 10, 2021), tonyfoale (Feb 5, 2021), Tonyg (Feb 7, 2021), Toolmaker51 (Feb 4, 2021), trevor_60_r (Feb 5, 2021)
    Sep 2018
    nova_robotics's Tools
    Dammit. More stuff I didn't know I needed.
  4. The Following 4 Users Say Thank You to nova_robotics For This Useful Post:
    EnginePaul (Feb 10, 2021), NortonDommi (Feb 6, 2021), Scotsman Hosie (Feb 10, 2021), Toolmaker51 (Feb 4, 2021)
    Like it? Same effect by hollowing out a boring bar [even shopmade] somewhat [a tapered hole is even better] then drill and tap end for big set screw or pipe plug. Fill with small lead shot [not molten] and thin grease. Tighten plug and top off repeatedly, until you don't get any more compression. Some guys put in a little vent hole, plugged by grub screw. Another expedient is to lube the ways heavily.
    Voila. No, it might not get feed rate demonstrated, but isn't many hundreds of dollars apiece either. Also C1045 is among highest machinability rating, they don't mention spindle bearings or other conditions.
    Videos with excess show-boating like the intro, always peak my suspicion meter.
  6. The Following 8 Users Say Thank You to Toolmaker51 For This Useful Post:
    DIYSwede (Feb 5, 2021), EnginePaul (Feb 10, 2021), fizzloid (Feb 5, 2021), freddo4 (Feb 5, 2021), NortonDommi (Feb 6, 2021), nova_robotics (Feb 4, 2021), Paul Jones (Feb 5, 2021), Tonyg (Feb 7, 2021)
    Sep 2018
    Awesome tip. Thanks.
  8. The Following User Says Thank You to nova_robotics For This Useful Post:
    I have several large boring bars that I made from thick wall steel tube which are filled with lead. That is, poured in when molten. This gives more mass than lead balls.
    It would be interesting to compare results with your lead shot and grease. Lead does not resonate.
  10. The Following 3 Users Say Thank You to tonyfoale For This Useful Post:
    freddo4 (Feb 5, 2021), Paul Jones (Feb 5, 2021), Toolmaker51 (Feb 5, 2021)
  11. #6
    Way back in time, working in 70's era mold shop, the lead and grease thing came in this way. One mentor [a cast bullet shooter] advised us lead shrinks slightly as it chills. The plug tightens it, dampening vibration well, in a tapered bore. Our non-scientific hypothesis said that a cylindrical shape wouldn't attain as much contact between lead and the bar interior. Cerro/ bismuth metal would have worked but the volume meant high cost, I suppose.
    Regarding tapered bore, a true taper is possible but depth was an issue. They relied on mere step drilling. The difference of which end, tool bit or tool holder, worked better wasn't solved. IMO, variables of machine condition, feed & speed rates, tool form, cavity size of mold etc too extensive to formulate. These were large trashcan like profiles, radii at top lip, stacking band, and bottom, requiring male radius form tools. That allowed good feed rate but a real pucker-fest disengaging at exact depths while backing off cross slide. Carriage stop not good for that. No DRO's or CNC's back then either, just creeping up on long travel indicators or Trav-A-Dial.
    Come to think of it, still prefer watching an indicator count-down instead of DRO doing that slot machine act.
  12. The Following 3 Users Say Thank You to Toolmaker51 For This Useful Post:
    freddo4 (Feb 5, 2021), Paul Jones (Feb 5, 2021), tonyfoale (Feb 5, 2021)
  13. #7
    I thought about shrinkage and as a (probably unnecessary) precaution I heated the steel tube to red before pouring in the lead. This gave scope for the tube to contract onto the lead. I never attempted to measure if it did but there has never been any sign of a loose core and I must have made three 55+ years ago. I did think of trying to "tin" the inside but it worked without it and it did not seem an easy thing to do. In any case I am not so sure that a loose core would be detrimental.
    I once tried something just for fun without intention of using it for real. I fixed a relatively small diameter rod to the back end of a boring bar with a mass that could be moved back and forth. This was an harmonic damper and it could be tuned to stop chatter. It was great but I considered it too much hassle to use as a workshop device. I wonder if the bar in the video works on a similar principle but inverted and put up inside instead of dangling out the back like mine.
  14. The Following User Says Thank You to tonyfoale For This Useful Post:
  15. #8
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Interesting concept and design and will check it out. Several years ago I started using only solid carbide boring bars for holding my carbide inserts. A world of difference when doing internal lathe boring with no chatter but an expensive initial cost. Also, changing out the carbide inserts sooner than latter makes a big difference. There are some great solid carbide boring bar bargains currently found using eBay.
  16. #9
    The adjustable damper/ balancer is worthy but cumbersome yes. But those are used on rifle barrels for tuning out harmonics. They are threaded because there is no concrete setting, once again due to variables.
    There is a tendency in boring to run inefficient RPMs and feed rates, sometimes bumping one up or down is all that's needed.
    On boring bars, tightly wrapped strip of inner tube is one remedy, and secure wraps of lead wire work too. Noise or not, two simple tests; very laborious. As bar enters hole watch the chips. They should pour off, not hop around and fall off. Lay something like a pencil on the bar, chatter does not always result in sound.
    Either way, chatter is not effective cutting. Looses size control, surface finish, and both interfere with mating parts.
    Just occurred in the foggy mist; try a split shaft collar, or split tubing and hose clamps........
    Last edited by Toolmaker51; Feb 5, 2021 at 03:26 PM. Reason: foogy mist; just like it says.......
  17. The Following 3 Users Say Thank You to Toolmaker51 For This Useful Post:
    NortonDommi (Feb 6, 2021), nova_robotics (Feb 6, 2021), trevor_60_r (Feb 5, 2021)
  18. #10
    Claudio HG's Avatar
    Sep 2019
    Venetian Alps, EU
    Claudio HG's Tools
    The principle shown in the video seems to be different than filling the boring bar with lead. The latter increases the mass, the former induce a dumpening due to the internal mass but mediated through the elastic rings. (Intuitively) the transfer function seems to be different because just increasing the mass simply shifts the frequencies at which the oscillations take place, while adding those elastic elements insert somewhere a constant factor (dumping) into the formula.
    The grease and lead balls seems to be similar to the solution shown in the video, but cheaper and simpler , because the grease can't introduce any delay* but only a dumping factor (due to [the small] compressibility).
    I wonder what happens to rigidity.
    Remarks:
    *The delay comes from the Newton's second law: F = m a = m (dv/dt). The "dt" argument introduces the "delay", or better a time shifting factor in the transfer function of the motion from workpiece on the spindle (in the case of the lathe) to the boring bar holder. We can use this transfer function to assess the stability of the system composed by the workpiece in rotation (as action) and the boring bar (as reaction) and a noise generator determined by the point of contact of the tool with the workpiece. This noise will induce oscillations that could increase in aplitude if the system resonates (i.e., it's not stable).
    N.B. This is to explain my intuition, I do not know if this is the common way to model a system like this.
  19. The Following 2 Users Say Thank You to Claudio HG For This Useful Post:
    NortonDommi (Feb 6, 2021), Toolmaker51 (Feb 5, 2021)
