Hello,
For a project I am working on, I need to be able to sand wood in narrow grooves. This is impossible by hand, which is why I came up with this solution. Hopefully this will help you if you have a similar problem.
Greetings
C
Andyt (Oct 18, 2019), Jon (Oct 16, 2019), mwmkravchenko (Oct 19, 2019)
Thanks Christofix! We've added your Groover and Slotting Attachment to our Woodworking category,
as well as to your builder page: Christofix's Homemade Tools. Your receipt:
New plans added on 09/04: Click here for 2,441 plans for homemade tools.
Christofix (Oct 16, 2019)
there is only 2 things that causes me concern one is the diameter of the disk is far too large for thst sixed rt angle grinder and 2nd would be the ultra high RPMs the grinder runs at while having an oversized disk mounted to it.
Tuomas (Oct 18, 2019)
It's a common oversight here Frank that things which spin at 12,000 rpm aren't given any evaluation of the significant effects of rotational dynamics. Seemingly strong things explosively fly apart when spun fast and unbalanced.
For instance a 5" diameter by 1/2" thick balanced birch plywood disc rotating at 12,000 rpm has a total force of greater than 3500 Newtons acting on it. That's a lot.
I wouldn't stand within 25' of that thing in motion.
