Percussion log splitters are very clearly dangerous, A portable saw is far safer:
Next Darwin candidate, or is it participant?
Agreed. Horrendous. Starting with goofy turned down hat brim. What blade?
Without enough inertia for a sure cut, throws your timing off.
Hello emergency room, goodbye digits. The terrain says one not around the corner either.
I see his key-way cutting skills did not stand the test of time! His solution rather appalled me, welding the shaft at both ends to the gear hub! :-(
Severe thumbs down for that! His one bolt fastening of the electric motor, was right up there with Heath Robinson, too!
His lack of materials lead to a couple of design anomalies... see the bottom of the gearbox mounts...
