Results 1 to 4 of 4
Thread: Airplane crank engine cutaway - photo
    baja (Mar 11, 2020), greyhoundollie (Mar 10, 2020), Rangi (Mar 10, 2020)
    Aug 2018
    Is this a flat 8 opposed engine? Or is it a flat 4 non-opposed engine? Or is this an 8 cylinder engine block combined into a 4 cylinder engine with a 4 piston air pump? A different angle on the picture taking would have helped a bit.
    This wiki shows all types of aircraft engine starters and start methods. This engine doesn't seem to be covered.
    https://en.wikipedia.org/wiki/Aircraft_engine_starting
    Lake Tahoe
    IntheGroove's Tools
    I believe that is the right side of a Wright-Hisso V-8...
  5. The Following User Says Thank You to IntheGroove For This Useful Post:
    greyhoundollie (Mar 11, 2020)
    Aug 2018
    Thanks In the groove. I think you are right.
  7. The Following User Says Thank You to greyhoundollie For This Useful Post:
    IntheGroove (Mar 11, 2020)
