Thread: Air compressor build in progress
    I traded for this compressor and a tank a few years ago
    rather than disassemble the compressor pack I just decided to weld it to the top plate on the tank.
    so last week I finally got around to ordering the necessary parts to complete it.
    things like the check valve the pressure switch and relief valve the gage and a few other things so maybe this week I can get it going
  2. The Following 8 Users Say Thank You to Frank S For This Useful Post:
    Altair (Dec 2, 2019), baja (Nov 5, 2019), emu roo (Dec 19, 2021), high-side (Nov 5, 2019), mwmkravchenko (Apr 3, 2022), rlm98253 (Nov 17, 2020), Seedtick (Nov 4, 2019), thevillageinn (Nov 17, 2020)
    well at long last I finally got around to finishing up my air compressor build the final piece required re bending a work hardened 3/4" copper line
    the compressor is under powered with the motor that is on the unit but it was already mounted with the compressor head when I got it
    I haven't installed piping in my shop yet so no need to run the compressor as of yet I only plugged it in long enough to make sure it will pump air but not long enough to allow it to fully build up a tank full of pressure as the oil in the compressor needs changing
    Thanks Frank S! We've added your Air Compressor to our Air Compressors category,
