Results 1 to 7 of 7
Thread: ...after a long time, I've made a grinding rig but something went wrong
    Claudio HG's Avatar
    Sep 2019
    Venetian Alps, EU
    Claudio HG's Tools
    Hello everybody. It's past a long time since my last post. The last months were, you know, troublesome.
    This project, that was kind of an experiment, was prompted by the need to cut at an angle steel parts to make the dovetail ways for a cross slide of a DIY lathe that I'm building.
    So I conceived a rig that, exploiting an angle grinder, should allow to make a titled, quite precise cut (that was the theory) on steel bars. But things not always turn out as expected.
    This is the video where I show the making of, and what went wrong.
    Cheers.
  2. The Following 10 Users Say Thank You to Claudio HG For This Useful Post:
    Carnel (Jun 25, 2020), dubbby (Jun 25, 2020), Jon (Jun 25, 2020), Moby Duck (Jun 29, 2020), olderdan (Jun 25, 2020), Philip Davies (Jun 25, 2020), Scotty12 (Jun 24, 2020), sossol (Jun 24, 2020), uv8452 (Sep 16, 2022), WorkerB (Jun 25, 2020)
    Thanks Claudio HG! We've added your Grinding Rig to our Grinding category,
    as well as to your builder page: Claudio HG's Homemade Tools. Your receipt:
    Mar 2019
    Adelaide, Australia
    Thanks for your honest and “Brave” post. Best of luck with the next version.
    Claudio HG's Avatar
    Sep 2019
    Venetian Alps, EU
    Claudio HG's Tools
    Thank you mate.
    Oct 2014
    Coronado, CA
    Thanks for the video on your Grinder Video
    Quote Originally Posted by Claudio HG View Post
    Cheers.
    olderdan's Tools
    Hi Claudio
    You my get there if you provide a depth of cut adjustment for .1 mm passes, this type of grinding needs rapid passes with small cuts, very time consuming but I dont think that will bother you too much. Dry grinding generates a lot of heat very quickly and the wheel will expand as well as the metal. Angle grinding wheels are too hard for this kind of work. Maybe a belt grinding set up would work but still needing some fine adjustment. Good luck with it and thanks for the enjoyable video top marks for enthusiasm.
  8. The Following User Says Thank You to olderdan For This Useful Post:
    Claudio HG (Jun 26, 2020)
  9. #7
    Claudio HG's Avatar
    Sep 2019
    Venetian Alps, EU
    Claudio HG's Tools
    Thank you mate. You are right about the depth of cut. I admit I was a little bit lazy and made this rig just as an experiment without paying too much attention to details. However now I feel kind of revenge desire I'm thinking to make a new version of the rig, but sticking again on the original idea of cutting rather than grinding down....after a long time, I've made a grinding rig but something went wrong-next-rig.png
