Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Adjustable coiled tube straightening tool
    Nice work, sir! Impressive results!
  2. The Following User Says Thank You to rebuilder1954 For This Useful Post:
    thehomeengineer (Feb 20, 2024)
  3. #12
    Dec 2016
    Ralphxyz's Tools
    Is the straightening jig adjustable for different tube sizes? What drives the tube through the jig? Lie to see a video of it in action!
    Berkshire UK
    thehomeengineer's Tools
    Hi Ralph
    The jig is full adjustable. The main frame is slotted so the rollers can be adjusted to suit the tube diameter. The copper was initially uncoiled by hand then pushed forward and backwards through the jig by hand. Whilst doing this the tube is also rotated at the same time. After 4/5 passes the tube is straight. The current tubes will then be cut into three pieces. 68 x 9” tubes are required for the boiler.
    Thank you for your interest
    The Home Engineer
  5. The Following User Says Thank You to thehomeengineer For This Useful Post:
    Ralphxyz (Feb 24, 2024)
  6. #14
    Dec 2016
    Ralphxyz's Tools
    Is that going to be a steam fired boiler heating hot water?
  7. #15
    Berkshire UK
    The boiler is a made from copper, silver soldered together, coal fired and the engine should hopefully work at 80psi. The boiler will need to be photographed to show the boiler inspector the internal soldered joints or be taken to be verified so you can proceed with the build. Once finished the boiler will have to be hydraulically tested at twice working pressure and if passed a second check has to be made in steam to ensure the safety valves lift at the correct pressure and any other leaks that may occur from fittings etc are not present. The inspection is carried out by a local model engineering society and this is needed as well as insurance to run the model in public areas. The hydraulic test has to be carried out in the future at normal working pressure.
