Results 1 to 10 of 13
Thread: An Accidental Hand Stamp Guide
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Using hand stamps should be a science, not an art. Today I decided that my hand stamp skills needed to be improved so the results were clear and consistent. Along the way I stumbled into a bit of scrap metal that made a great stamp guide plus learned a few things about my stamping set.
    https://rick.sparber.org/AnAccidentalHandStampGuide.pdf
    Thanks,
    Rick
    Rick
  2. The Following 10 Users Say Thank You to rgsparber For This Useful Post:
    baja (Jan 8, 2021), Jon (Jan 3, 2020), LMMasterMariner (Dec 24, 2018), mklotz (Dec 23, 2018), PJs (Dec 26, 2018), Ralphxyz (Jan 7, 2021), Seedtick (Dec 24, 2018), Sleykin (Jan 8, 2021), threesixesinarow (Dec 24, 2018), Tiny (Dec 31, 2018)
    DANG Good Idea
    Well DANG! THAT is a good idea. Can’t tell you how many times my steel stamping was crooked over the years.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I’m working on a simple attachment to compensate for rotated letters. The glue is still setting up. Stay tuned.
    Rick
    Rick
  5. The Following User Says Thank You to rgsparber For This Useful Post:
    PJs (Dec 26, 2018)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I just published version 2.0. It offers a way to indicate when the letter will be up-side-down plus an additional attachment that minimizes letter rotation.
    Rick
    Rick
    Thanks Rick! We've added your Hand Stamp Guide to our Miscellaneous category, as well as to your builder page: Rick's Homemade Tools. Your receipt:
    ranald (Dec 30, 2018)
  10. The Following User Says Thank You to tonyfoale For This Useful Post:
  11. #7
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    Thanks Tony & Rick. I've often considered buying a set for marking woodwork but remembered a mechanics mess he made on a diesel engine head as required by a transport dept person (why?) when i wanted to register a truck I had all receipts etc. Anyway, I haven't been able to find anything appropriate for my simple idea:THERE IS ONE OUT THERE. I DON'T WANT A BURN ON type STAMP as I will sometimes require it over a finish. Needs to be adjustable for year also.
    ANYONE, ANY IDEAS?
  12. #8
    Mr.Pete's Avatar
    Nov 2015
    wow this is a wonderful tool ! so simple to make I going to make one too keep up the good work !
  13. #9
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by ranald View Post
    ANYONE, ANY IDEAS?
    Could a metal plate attached with screws work? If so, it could be stamped or etched. There is a lot of information available on transferring laser printed artwork to metal. If copper, it can be etched like a circuit board. If steel, it can be etched with DC current and salt water.
    Rick
    Rick
  14. #10
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Tony,
    Wonderful solution! I particularly like being able to stack stamps tightly yet hit one at a time with the rod.
    It does appear that you are using a better grade of stamp than I own. I suspect that none of your letters are rotated relative to the shank of the stamp.
    There is still some "art" involved with all of these solutions: adjusting the striking force as a function of the amount of imprint. Stamping an "I" takes a lot less force than stamping an "M". I was playing with an adjustable length sleeve that would absorb the hammer blow after the punch went in a set distance. It did not work well enough to justify proceeding. Using an arbor press is another way to control imprint depth but it is limited to flat stock that can fit in the press.
    I wonder if you could replace your rod with a screw with two nuts on it. Adjust the nuts so they lock while just enough of the screw extends below them. The hammer blow would drive down the screw and stamp until the bottom of the lower nut hits the top of the support frame. This would insure that all stamps went into the base material to the same depth.
    Rick
    Rick
