Hi
im not sure is this a "tool".
But this way i notch tubes.
baja (May 22, 2021), bruce.desertrat (Feb 13, 2018), BuffaloJohn (Jul 26, 2021), carloski (May 22, 2021), cmarlow (Jan 17, 2019), DIYer (May 8, 2017), Duke_of_URL (Jan 18, 2019), Eaglewood (Jan 17, 2019), EnginePaul (Jun 17, 2018), Glebson (May 9, 2017), glenntref (Feb 14, 2018), high-side (Jan 20, 2019), JD62 (May 8, 2017), Ken Koch (Mar 30, 2019), LaVern (May 8, 2017), Moby Duck (Jun 19, 2018), nickyd (May 12, 2017), oldcaptainrusty (Feb 14, 2018), oldpastit (Jan 18, 2019), Ralphxyz (Dec 22, 2023), rebuilder1954 (Jul 1, 2024), Resident114 (Dec 21, 2023), rlm98253 (Feb 13, 2018), Ron725 (May 9, 2017), SA MAKER (May 9, 2019), Scotsman Hosie (Feb 22, 2018), Seedtick (May 9, 2017), Sprig1 (Mar 25, 2019), that_other_guy (Mar 25, 2019), toma (Feb 14, 2018), Tonyg (Oct 17, 2018), Toolmaker51 (Jun 17, 2018), wesser1 (Dec 21, 2023), will52100 (Jun 17, 2018), william73 (Jul 18, 2018)
Thanks Tuomas! We've added your Tube Notching Method to our Tube Notchers category,
Tuomas (May 12, 2017)
Thanks Ralph.
Tube was with 1.6mm wall. But also those 1mm thick discs cut very fast, i like those are more accurate too than 2.4mm discs.
Paul Jones (Feb 22, 2018), sniffipn (May 22, 2021)
Tuomas (May 11, 2017)
There's a product here. Design templates for standard and common tube sizes and a variety of angles of intersection, 90deg. 75, 60, 45, 30 and maybe in between. Print the templates at home on heavy paper stock and ship them by 1st class mail or via internet. Or laser cut more durable templates from a thicker flexible material, incorporate a connector of some sort. The material could be strong so not to stretch or stretchy thick rubber/elastomer with ends laser cut to form a male/female joint that you glue together with ACC. This later type could be designed to fit a small range of OD's for example: 1.75, 1.88, 1.9(schedule 40 pipe) and 2". I'm thinking this particular example in a quality silicone rubber could easily sell for $4.95 plus shipping, which if it would stand being pressed flat for shipping between two sheets of cardboard, could go first class perhaps as many as a set of 6 sizes in a first class envelope. Ed Weldon (to old to start a new business)
Toolmaker51 (Oct 19, 2018)
I forgot to mention in the product idea. I may have also produced a "poor man's patent" here by making a public disclosure in this forum of what otherwise might be a patentable idea, laser cut form and connectors that stretches to fit a variety of sizes. It could also be die cut. Careful selection or fabrication of the right material and thicknesses could accomodate the tendency for narrower widths of the template to stretch unequally. Ed W
Another thought. This form could be cut with a steel rule die, a method commonly used for cutting flat gaskets. Dies are made from special thin steel strip with a sharp cutting edge embeded in thick baltic birch plywood. Check out this process. Cheaper than buying a laser. And faster production rates.
PJs (Jun 21, 2018), Scotsman Hosie (Mar 26, 2019), sniffipn (May 22, 2021), thevillageinn (Jun 21, 2018), Toolmaker51 (Oct 19, 2018)
