Results 1 to 5 of 5
Thread: 360-degree electric fan - GIF
    blkadder (Dec 30, 2020)
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    I really want one of these.
    Ron
    ...Semper Fidelis...
    Supporting Member Big Sexy's Avatar
    I wonder if the blades are powered by a motor being energized by something like slip rings or a commutator, or if the motor is in the base or top and using gears to spin the assembly and the fans via gears.
    I bet Frank would know.
    Aug 2018
    I was thinking the same things as you Big Sexy, with one more possibility, could the fans be turning because one of them is mounted slightly off center so that the fans turn because of that imbalance.
    Ooh I didn’t think of that.
