Results 1 to 5 of 5
Thread: 3-axis clamp
    bmr27's Avatar
    bmr27's Tools
    3-axis clamp
    Borring rainy sunday afternoon
    so I decideed to use it to finish my clamp
    something I started
    prepared parts for assembling and put it on hold
    so,here's a start
    all parts on the table,even more then necesary
    and,unavoidable cup of coffe
    the base is 100x100 mm L-profile (4x4 inch) which has been milled to take out radius in the angle
    and 15 mm thick peace of sheet 200x200 mm
    I left hanges to cool out while I was driiling wholes and tapping threads
    I decided to fit all joints by bolts
    to avoid aany distosions that could be caused by welding,to keep it square
    and...
    as the psotos say to you
    then I was drilling wholes and fitting stuff an I forgot to take more photos step by step
    for down lock I used a 20 mm thread with peace of 40x40 mm box cut under 45 degrees
    for uper lock it's a 16 mm thread
    right hine has pin that easily goes in and out for easier unlocking
    and that's it
    I'd like to see your comments here
  2. The Following 4 Users Say Thank You to bmr27 For This Useful Post:
    C-Bag (Mar 9, 2016), Jon (Mar 6, 2016), kbalch (Mar 8, 2016), PJs (Mar 9, 2016)
    Thanks Pat! We've added your 3 Axis Clamp to our Clamps category, as well as to your builder page: bmr27's Homemade Tools. Your receipt:
    Feb 2015
    Manitoba Man's Tools
    bmr27
    I was intrigued by the title of your project. Now that I see what it is I need to use you ideas. I have a cast iron 90 degree corner vise but was wondering how to add the vertical element. Thanks to you I see where I need go. Keep up the good thinkering.
    Bob
  5. The Following User Says Thank You to Manitoba Man For This Useful Post:
    PJs (Mar 16, 2016)
    bmr27's Avatar
    bmr27's Tools
    hy guys
    I'm glad lots of you have seen my work
    as always,when the job is done you see where you did wrong and what improvements could be made
    so the next one is going to be even better
    see you soon with some new stuff
    May 2014
    Del Mar, California
    Paul Jones's Tools
    bmr27,
    Nice design and I like the stick shift knob for the bottom clamping screw.
    Paul
