Results 11 to 20 of 27
Thread: 2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)
    Dec 2016
    bobs409's Tools
    Belt Grinder Radius Forming Jig:
    I just finished up this radius forming jig attachment for the belt grinder. If the part your working on has a hole, this will allow you to form a radius around it. Jig simply drops into the existing table arm allowing adjustment in/out and up/down. Can work with both the contact wheel shown or the flat platen.
    I have created an assortment of pins ranging from 1/8" to 1 inch but others can be made as needed. They are all stored on an aluminum rack for safe keeping.
    Table inward movement is done by use of the handle that rotates the table in and out. An adjustment knob can set the depth of this which is good for making repeatable parts.
    Just install the correct size pin, place part over it and rotate left and right while slowly bringing the part into the wheel. It literally takes seconds to produce a beautiful formed radius.
    In addition, the table tilts so forming a beveled radius is just as easy!
    2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad1.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad2.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad3.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad4.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad5.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad6.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad7.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad8.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad9.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-rad9b.jpg
    Download plans for belt sanders and grinders.
  2. The Following 11 Users Say Thank You to bobs409 For This Useful Post:
    Andyt (Apr 16, 2020), Duke_of_URL (Apr 20, 2020), high-side (Apr 16, 2020), Jon (Apr 16, 2020), matt_albitz (Apr 16, 2020), Rangi (Apr 16, 2020), rgsparber (Apr 19, 2020), rlm98253 (Apr 16, 2020), Tonyg (Apr 20, 2020), tuchie (Jul 13, 2024), Tule (Apr 15, 2020)
  3. #12
    Oct 2018
    Wow.
    That is one of the nicest grinders i have ever seen.
    Awesome work, Man
  4. The Following User Says Thank You to Phil.rvc For This Useful Post:
    bobs409 (Apr 15, 2020)
  5. #13
    Thanks bobs409! We've added your Radius Forming Jig to our Belt Sanders and Grinders category,
    as well as to your builder page: bobs409's Homemade Tools. Your receipt:
  7. #14
    Dec 2016
    bobs409's Tools
    Forgot to mention that you can also produce circles with this jig. I made a few today to test it out. I did one in 1/4 inch steel plate and I sandwiched (2) 14 gauge plates together and did both together. Worked great! I also added a push down handle to the belt tension arm.
    2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-dscn3798.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-dscn3801.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-dscn3803.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-dscn3808.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-dscn3809.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-dscn3799.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-dscn3800.jpg
  8. The Following 4 Users Say Thank You to bobs409 For This Useful Post:
    high-side (Apr 16, 2020), matt_albitz (Apr 16, 2020), rgsparber (Apr 19, 2020), rlm98253 (Apr 16, 2020)
  9. #15
    Jyväskylä Finland
    Tuomas's Tools
    Nice build there!
    Sorry about stealing your picture.
    But i was wondering that could this be useful?
    If you cut the table to follow the shape of the belt ( black line on the picture).
    Then it would be possible to place table closer to the belt, and use that tilted lower wheel for grinding internal curves?
  10. The Following 3 Users Say Thank You to Tuomas For This Useful Post:
    bobs409 (Apr 16, 2020), Moby Duck (May 6, 2020), rlm98253 (Apr 16, 2020)
  11. #16
    Dec 2016
    bobs409's Tools
    Nice build there!
    Looks like a great idea to me! Maybe make a separate table just for that. The possibilities seem to be endless with these grinders. That's what I like about building my own tools.
    Thanks for the input!
  12. The Following User Says Thank You to bobs409 For This Useful Post:
  13. #17
    Supporting Member diyfixman's Avatar
    Jan 2019
    diyfixman's Tools
    It's just an amazing job! I salute you
    Amazing Videos and DIY Guides, Explanations, Tips, Tricks and Much More...
    Facebook Page | YouTube channel
  14. The Following User Says Thank You to diyfixman For This Useful Post:
  15. #18
    Dec 2016
    bobs409's Tools
    Oh no, he's still at it! Another attachment!
    Today I introduce a bevel jig invention for the 2 x 72 belt grinder.
    The pictures and text tell the story. Basically it's used to produce an even bevel across the part, all the way around or from part to part depending on the situation. Repeatable! Trying to achieve this by hand is difficult, but not with this tool!
    P.S. don't you just love the adjustment wheel? I bought that 4 inch round outer ring at my metal supplier last year and was just waiting for an excuse... You can also practice your driving but sorry, the horn doesn't work.
    2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev1.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev2.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev3.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev4.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev5.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev6.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev7.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev8.jpg2 x 72 inch Revolution Belt Grinder (aka The Metal Muncher!)-bev9.jpg
  16. #19
    House_Work's Avatar
    Sep 2019
    Naples, FL
    House_Work's Tools
    Bob this is such a great addition to the Revolution Grinder! Are you okay with me using your photos on my website? I would like to share your work on my YouTube Channel also.
    If anyone is interested in building my grinder here is a link to the plans: https://housemade.us/products/revolu...-grinder-plans
    Here is a video of the build as well:
    - Brian
    - Brian House
    www.HouseMade.us
  17. The Following User Says Thank You to House_Work For This Useful Post:
    bobs409 (Apr 26, 2020)
  18. #20
    Dec 2016
    bobs409's Tools
    Quote Originally Posted by House_Work View Post
    - Brian
    Sure can Brian! Thanks for the kind words. I've got a few more "add on's" coming very soon. lol
