Page 33 of 33 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
Results 321 to 322 of 322
Thread: 1974 XS/TX650 rebuild
  1. #321
    Oct 2015
    th62's Tools
    The cylinder won't hold pressure so I should increase the ring gap. Yeah, that makes sense, now why didn't I think of that?
  2. #322
    Oct 2015
    th62's Tools
    Valve grinding
    Valve grinding.
    I ground the valves in but they still leaked. So I pulled them and found the seats way to wide, they won't seal if too wide. Yamaha says, 1.3mm. So I mounted the valves on the lathe and using a drum sander in a rotary tool ground the back of the valve down so the seat was 1.2mm wide. The edges are around .5mm or better.
    I sent off for a 30 degree cutter head a while back, but didn't have a handle for it, so turned up a handle from stainleas with a 10/11mm taper to suit the cutting head and an 8mm shaft to fit the valve guide and cut behind the seats in the head until the seats were also 1.2mm.
    Once all that was done, I lappd the valves with fine paste, then assembled with springs and collets and poured fuel into the port to test for leaks.
    The last pic shows a piece of dry, clean paper towel held around the edge of the valve by small magnets. The paper towel shows up any leaks.
    Now I know all the armchair experts will say wrong, wrong, wrong, should have used a collet instead of a three jaw, should have done this, that and the other. It'll probably surprise you armchair experts but I do things my way, the way I know works and how I've been doing it for the last 50+ years. I really couldn't give a hoot how you do it.
    Attached Thumbnails Attached Thumbnails 1974 XS/TX650 rebuild-1.jpg   1974 XS/TX650 rebuild-2.jpg   1974 XS/TX650 rebuild-3.jpg   1974 XS/TX650 rebuild-4.jpg   1974 XS/TX650 rebuild-5.jpg
    1974 XS/TX650 rebuild-6.jpg   1974 XS/TX650 rebuild-7.jpg   1974 XS/TX650 rebuild-9.jpg
