Results 1 to 4 of 4
Thread: 191. No more drill bit flexing and breaking
    Supporting Member Make Things's Avatar
    Dec 2018
    Midwest, USA
    Make Things's Tools
  2. The Following User Says Thank You to Make Things For This Useful Post:
    Floradawg (Dec 3, 2023)
    Aug 2012
    Australia
    desbromilow's Tools
    NOT sure about this.... I was always led to believe that drill shanks are softer (annealed HSS) compared to the harder flutes. Gripping a hardened flute seems like a recipe for cracking/chipping the flute, or damaging the chuck jaws.
    thoughts?
  4. The Following User Says Thank You to desbromilow For This Useful Post:
    BuffaloJohn (Nov 28, 2023)
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Quote Originally Posted by desbromilow View Post
    thoughts?
    I think you're definitely correct that the shanks are softer, but how hard are you bearing down on the chuck? In my own experience, I have never damaged a flute or the chuck jaws. But I would assume the chuck jaws are hardened themselves, so the biggest concern would be the drill bits. Gripping them lower prevents them from wandering which can bend or break the bits in the long run.
    Dec 2017
    NeiljohnUK's Tools
    thoughts?
    Stub drills exist for this reason, many/most CNC drilling jobs are done with a stub drill to start with if not the whole job. You can create stub drills from old worn/broken jobber bits, though the split point most commercial stub bits are made helps avoid wander even more.
  7. The Following User Says Thank You to NeiljohnUK For This Useful Post:
