Results 1 to 10 of 12
Thread: 170 Amp MOT Stick Welder
    Supporting Member scorch's Avatar
    Apr 2015
    Oakdale, MN
    scorch's Tools
    Home made Microwave Oven Transformer (MOT) stick welder. I based my design on the welder by Daniel B. Hartman (Dan's Workshop). This welder is made from four transformers from old microwave ovens. The transformer secondary coils were rewound, to achieve welding voltage, with 6 AWG solid copper wire. I included two fans from one of the microwaves for cooling. The power adjustable so it can be used with various sized of welding rod. The SCR module used to adjust the power is mounded to a homemade heat sink made from two old aluminum frying pans.
    Input: 240V, ~25 Amp
    Open circuit voltage: 47 Volts
    Welding current: 170 Amps
    Rewound transformer secondary coils with 6 AWG stranded copper wire.
    Variable power provided via SCR module
    Welder installed on the shelf of a cart that I use for welding.
    Welder removed from the cart with the top cover removed.
    The SCR for the power control mounted to a homemade heat sink made from two aluminum frying pans.
  2. The Following 14 Users Say Thank You to scorch For This Useful Post:
    blkadder (Jun 16, 2015), EnginePaul (Oct 31, 2018), esaenzrn (Mar 19, 2018), FEM2008 (Aug 19, 2020), Jon (Jun 15, 2015), JRock (Nov 2, 2018), kbalch (Jun 15, 2015), mwmkravchenko (May 26, 2023), nova_robotics (Aug 19, 2020), olderdan (Mar 19, 2018), Paul Jones (Jun 15, 2015), rickmcolorado (Jul 12, 2018), Toolmaker51 (Oct 31, 2018), wimton (Sep 21, 2022)
    Feb 2013
    South of Brazil.
    Hotz's Tools
    wow great job, congratulations.
    Sorry my mistakes in english.
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks scorch! I've added your Stick Welder to our Electrical category, as well as to your builder page: scorch's Homemade Tools. Your receipt:
  5. The Following User Says Thank You to kbalch For This Useful Post:
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    This thread has been moved to the Must Read subforum. Congrats (and thanks) to scorch for making such a valuable contribution!
    Sep 2017
    Great job on the stick welder . Anyone happen to have plans for a small T.I.G. welder for small and hobby welding ?
    Last edited by LESTER MARTIN JR.; Sep 26, 2017 at 11:48 PM. Reason: left out something.
    Oct 2017
    Nice configuration! I've been wondering if more transformers would result in a better device. Seems like you nailed it.
  9. #7
    rickmcolorado's Avatar
    Jun 2017
    I would like to plans as well for a small hobby welding if someone has one. Thanks in advance.
  10. #8
    Apr 2018
    tig welder
    has anyone come with plans for a DIY 170 amp tig welder. I’m looking to make such a beast. Thanks😉
  11. #9
    Try this link for homemade TIG welders: Homemade Tools Search: tig welder - HomemadeTools.net
  12. #10
    Sep 2018
    nova_robotics's Tools
    Awesome work. The wooden box on a welder is no bueno. 1/8" aluminum is nice to work with if your experience and tooling is working with wood. You can even cut it with a circular saw. And the aluminum will help dissipate a lot of heat.
