Thread: 155. Fence alignment made easy (shorts tip)
    Supporting Member Make Things's Avatar
    Dec 2018
    Midwest, USA
    Make Things's Tools
  2. The Following 7 Users Say Thank You to Make Things For This Useful Post:
    homey_g (May 22, 2023), kboy0076 (May 20, 2023), lassab999 (May 20, 2023), rlm98253 (May 18, 2023), sossol (May 18, 2023), Toolmaker51 (May 23, 2023), verticalmurph (May 18, 2023)
    Great video! More useful info in 0:58' than minutes of common prattle and monetization interruptions.
    Using guide slot to ascertain alignment is nearly 100% reliable, if the blade alignment correlates. Some 'lesser' machines don't provide that adjustment; correction would be tedious.
    As the video shows, tactile verification is good, improve that with a slip of paper between surface/s/ and finger. It minimizes the different textures involved. A feeler leaf of minimal thickness also gives terrific results.
    Most milling machine users can recognize a making a pair of fixture keys, or using adjustable parallels, would achieve near perfection to set rip fence. This will be imperative, in attempt of ~250' of French cleat cabinet hanger (uhhh no; not continuous), but hopefully this fall.
