Homemade Worn Indicator Shaft Fix
mr_modify1 on homemadetools.net
Homemade worn indicator shaft fix constructed by reorienting the collar where the shaft slides through. Helps remove shaft play on an old dial indicator.
DIY Worn Indicator Shaft Fix - comment on how to build a Worn Indicator Shaft Fix - 0 comments
Be the first to comment on this DIY Worn Indicator Shaft Fix, or add details on how to make a Worn Indicator Shaft Fix! Click the "add comment" button above to comment.
