Homemade Oil Cooler Pressure Tester
boyt911sc on forums.pelicanparts.com
Homemade pressure tester for an oil cooler. Constructed from a water pump T-fitting, a tire valve mounted via a water hose fitting, and a pressure gauge. The tester is attached to the oil cooler by means of a short hose and worm clamps.
Nov 21, 2013 4:10 PM
DIYer
A simple rig that should work with most oil coolers.
URL:
FILES:
- Using steel plates as excavator track pads - GIF by Altair on 2024-05-01 21:51:01
- Fabricating stoves - GIF by Altair on 2024-05-01 20:27:01
- WWII fighter-bomber assembly plant - photo by Altair on 2024-05-01 19:13:01
- A tapping arm for the shed by Occasional machinist on 2024-05-01 17:09:49
- Workers installing ship engine - GIF by hemmjo on 2024-05-01 16:32:33
- Homemade hot wire bottle cutter - GIF by desbromilow on 2024-05-01 16:24:32
- Students cutting wood using a hacksaw - GIF by ductape on 2024-05-01 16:08:14
- Repairing bent truck wheels - GIF by Altair on 2024-05-01 15:42:01
- Cordless pressure washer from reciprocating saw - video by Jon on 2024-05-01 15:03:10
- Mini lathe split jaw chuck - video by Jon on 2024-05-01 15:02:40
