Homemade Floating Output High Voltage Power Supply
David Prutchi on diyphysics.com
Homemade floating output high voltage power supply constructed from a neon sign transformer, variac, diodes, Delrin, shellac, high voltage outputs, and a surplus panel meter.
DIY Floating Output High Voltage Power Supply - comment on how to build a Floating Output High Voltage Power Supply - 0 comments
Be the first to comment on this DIY Floating Output High Voltage Power Supply, or add details on how to make a Floating Output High Voltage Power Supply! Click the "add comment" button above to comment.
