Page 1 of 36 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... LastLast
Threads 1 to 20 of 717
Forum: Tool Tips and Tricks
Post your tool tips and tricks in here. The best tips are awarded a $100 prize. Videos and images of your tool tips are nice, but not necessary.
  1. Sticky Thread Sticky: Best Tool Tip of the Month - $100 monthly award
    Started by Jon, Mar 10, 2023 08:29 AM
    Mar 10, 2023, 08:29 AM Go to last post
  2. Sticky Thread Sticky: Thousands of homemade tool plans
    Started by Jon, Feb 26, 2020 12:29 PM
    Feb 26, 2020, 12:29 PM Go to last post
    Yesterday, 05:57 PM Go to last post
  1. 348. This is why belt sander doesn't sand flat
    Started by Make Things, May 26, 2026 04:02 AM
    belt sander
    May 26, 2026, 04:02 AM Go to last post
  2. Funnel bell punch
    Started by mklotz, May 23, 2026 12:03 PM
    May 23, 2026, 12:03 PM Go to last post
  3. 347. Turn your router into a jointer
    Started by Make Things, May 22, 2026 12:01 AM
    jointer, router
    May 22, 2026, 12:01 AM Go to last post
  4. Tight solder joint
    Started by thehomeengineer, Apr 16, 2026 11:50 AM
    May 18, 2026, 05:02 AM Go to last post
  5. 346. The gold standard of plywood
    Started by Make Things, May 14, 2026 04:29 AM
    plywood
    May 14, 2026, 04:29 AM Go to last post
  6. 345. Why This Saw Cuts the “Wrong” Way
    Started by Make Things, May 10, 2026 03:01 AM
    hand saw
    May 10, 2026, 03:01 AM Go to last post
    May 8, 2026, 04:08 PM Go to last post
  7. using multiple squares as a layout templet
    Started by Frank S, May 6, 2026 12:38 PM
    May 7, 2026, 04:27 PM Go to last post
  8. 340. Sticky notes / sharp ideas
    Started by Make Things, Apr 23, 2026 07:18 PM
    marking, sharpening
    May 7, 2026, 09:25 AM Go to last post
    May 2, 2026, 11:26 AM Go to last post
    Apr 30, 2026, 12:40 AM Go to last post
  9. 342. Glue trick EVERY woodworker should know
    Started by Make Things, Apr 28, 2026 12:39 PM
    glue
    Apr 28, 2026, 12:39 PM Go to last post
  10. 341. Retailer sticker sabotage: SOLVED
    Started by Make Things, Apr 24, 2026 12:05 PM
    Apr 24, 2026, 12:05 PM Go to last post
    Apr 19, 2026, 06:07 AM Go to last post
    Apr 18, 2026, 03:37 AM Go to last post
    Apr 17, 2026, 11:08 AM Go to last post
  11. 336. KYJ: Bridle joints - the chisel less mortise
    Started by Make Things, Apr 15, 2026 05:15 AM
    bridle, joints
    Apr 15, 2026, 05:15 AM Go to last post
  12. 335. Simple fix for consistent, accurate marks
    Started by Make Things, Apr 13, 2026 10:27 PM
    marking, measuring
    Apr 13, 2026, 10:27 PM Go to last post
    Apr 7, 2026, 02:55 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
