Thread: Lath Chuck Depth Stop
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Here I am turning a batch of pad cups for Keys, for woodwind instruments. It's made of nickel silver.
    It can be shaped out of metal sheet, but here, as I had a rod with the proper diameter, I decided to go machining them on the lathe.
    It's 12mm in OD, and rough cut at 2.5mm in depth.
    One face has a pointed head, and the other face needs to be hollowed to make room for the felt pad.
    I needed to find a way to chuck accurately these little odd shape pieces in a way that could allow some repetitive operations.
    So I decided to do something I have had in mind for a long time, which is a depth stop for my chuck.
    The first picture shows the idea.
    My chuck as, just behind the jaws, a 30mm diameter chamber before it touches the spindle plate. End there is yet an adaptative plate between them, with the same 30mm ID.
    So the idea was to make a kind of inner core that would fit this chamber, and would be able to hold a piece of threaded rod right along the axis, that could protrude between the jaws, serving as a depth stop.
    Additionally, here, as my pieces had an odd shape, I made a small negative head, screwed at the end of my depth stop, so that my workpieces are just chucked at the right depth and well aligned.
    The diameter of this stop is arranged to be just a little smaller than the diameter of the workpiece in order to get a proper grip on the piece.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 14 Users Say Thank You to Christophe Mineau For This Useful Post:
    bobs409 (Apr 30, 2018), DIYer (May 1, 2018), Eaglewood (Dec 12, 2018), emu roo (May 9, 2022), high-side (Sep 17, 2020), HUMARIA (Sep 16, 2020), Jon (Apr 30, 2018), LMMasterMariner (May 1, 2018), Metallurg33 (Aug 25, 2018), PJs (May 2, 2018), rossbotics (Apr 30, 2018), Seedtick (Apr 30, 2018), that_other_guy (Aug 28, 2018), Tonyg (Sep 16, 2020)
    Thanks Christophe Mineau! We've added your Chuck Depth Stop to our Workholding category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    New plans added on 12/02/2024: Click here for 2,609 plans for homemade tools.
    Steved53 (Sep 16, 2020)
    Jun 2018
    Stevohdee's Tools
    What a great idea, well done, thanks
  6. The Following User Says Thank You to Stevohdee For This Useful Post:
